登录系统首页报错,文件夹也报错
ZL_10925195
登录系统首页报错,文件夹也报错
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.0
登录系统首页报错,信息如下:
Windchill 错误
联系管理员以获得协助。 以下信息供参考。
请求 ID: -mkpxqrsozujq;m8pvwcvj;108274;wwupyg;2477
请求 URI: /Windchill/ptc1/comp/wt.pdmlink.PDMLinkProduct.infoPage
查询字符串: oid=OR%3Awt.pdmlink.PDMLinkProduct%3A15497647&u8=1&portlet=component
状况代码: 501
消息: A persistence error occurred. 嵌套异常是: wt.pom.PersistenceException: 出现持续性错误。
当前时间: 2025-03-26 20:31:17.337 +0800
Fadel
22-Sapphire III
(To:ZL_10925195)
Would you share any related error in logs
Fede
ZL_10925195
(To:Fadel)
2025-03-27 08:59:17,748 ERROR [ajp-nio-127.0.0.1-8011-exec-2] wt.pds.exception zeke.liu - Suppressing internal message
(wt.pom.pomResource/0) wt.pom.PersistenceException: A persistence error occurred. System message follows:
Nested exception is: wt.pom.DatastoreException: A SQL error has occurred. Database system message follows:
Nested exception is: java.lang.ArrayIndexOutOfBoundsException
	at java.lang.System.arraycopy(Native Method)
	at wt.units.Unit.readVersion_6722550756304252532L(Unit.java:2081)
	at wt.units.Unit.readVersion(Unit.java:478)
	at wt.units.Unit.readExternal(Unit.java:456)
	at java.io.ObjectInputStream.readExternalData(ObjectInputStream.java:2118)
	at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:2067)
	at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1573)
	at java.io.ObjectInputStream.readObject(ObjectInputStream.java:431)
	at wt.units.FloatingPointWithUnits.readVersion4226946163825851459L(FloatingPointWithUnits.java:273)
	at wt.units.FloatingPointWithUnits.readVersion(FloatingPointWithUnits.java:93)
	at wt.units.FloatingPointWithUnits.readExternal(FloatingPointWithUnits.java:72)
	at wt.pds.AbstractLobHandler.getLobAsObject(AbstractLobHandler.java:396)
	at wt.pds.SQLDatabasePds.getLobAsObject(SQLDatabasePds.java:1602)
	at wt.pds.WTResultSet.getLobAsObject(WTResultSet.java:1075)
	at wt.pds.WTResultSet.getObject(WTResultSet.java:349)
	at com.ptc.core.lwc.server._LWCAttributeDefaultValue.readExternal(_LWCAttributeDefaultValue.java:222)
	at wt.pds.WTResultSet.readObject(WTResultSet.java:679)
	at wt.pds.PersistableItemBuilder.build(PersistableItemBuilder.java:559)
	at wt.pds.StandardACProcessor.processResults(StandardACProcessor.java:99)
	at wt.pds.SequentialResultBuilder.build(SequentialResultBuilder.java:432)
	at wt.pds.BasicResultCursor.next(BasicResultCursor.java:93)
	at wt.pds.SQLDatabasePds.query(SQLDatabasePds.java:837)
