系统启动报错
志曾_10388909
系统启动报错
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.1.2
MethodServer报错,无法登录Windchill系统。MethodServer报错日志如下:
2025-04-21 18:49:49,949 ERROR [pool-8-thread-1] com.ptc.core.lwc.server.cache.TypeCachePrimer - Error priming the type cache. java.lang.StackOverflowError
at wt.cache.LinkedHashMapCache$InternalMap.get(LinkedHashMapCache.java:145)
at java.base/java.util.Collections$SynchronizedMap.get(Collections.java:2594)
at wt.cache.LinkedHashMapCache.get(LinkedHashMapCache.java:73)
at com.ptc.core.lwc.server.cache.AbstractAttTemplateCache.getTypeDefView(AbstractAttTemplateCache.java:205)
at com.ptc.core.lwc.server.cache.TypeDefinitionManager.getTypeDefView(TypeDefinitionManager.java:382)
at com.ptc.core.lwc.server.cache.TypeDefinitionManager.getChildTypeDefViews(TypeDefinitionManager.java:1564)
at com.ptc.core.lwc.server.cache.TypeDefinitionManager.getChildTypeDefViews(TypeDefinitionManager.java:1565)
AndrewK
Community Manager
(To:志曾_10388909)
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • Could you provide more information about your environment? For example, the operating system, and database being used.
  • Have there been any recent changes or updates to your Windchill PDMLink system, such as patches, upgrades, or configuration changes?
  • Have you tried any troubleshooting steps so far, such as restarting the MethodServer, clearing caches, or checking for memory issues?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
This could be a tuning issue: https://www.ptc.com/en/support/article/CS297624?source=search
Do you have a lot of types or cascading attributes?
The error message is not related to Login operation.
Make sure the Methodserver is ready,  attache the full Methodserver log and the screenshot of the error message when failed to login to the system.
