Regarding Pro/INTRALINK 3.4.
I wonder if anyone have come accross .prt, .asm and .drw files in the vaults which are empty (0 kb) and of course can't be opened in Pro/ENGINEER?
Secondly, does anyone know how a .prt, .asm and .drw file in the vault folderscould have a different Modified date thanCreation date?
Best Regards,
Hans
Hello Hans,
I've seen the 0 kb issue before in Intralink 3.4. Ours happened due to mass import of data. I suspect that at the time of the import, components were suppressed, or there was some other link that created the metadata, but did not import the geometry file. Only way to fix was to create new geometry or recover the original geometry from the archive and check it in as latest.
Joshua Houser
(have I talked to you about FIRST robotics yet?)
Pelco by Schneider Electric
MCAD Range Technical Officer
Hi Hans,
have you already run the Extra Object Report (also known as Orphan File Report)?
This report detects all files in the file vaults, which are
