10.1 M020 Business Rules
pwilliams-3
Has anyone configured any business rules that are newly available in 10.1 M020? I have read all of the WHC documentation on this but some things are still a bit unclear. Such as:
1. How to define all of the xml elements correctly in the rule file?
2. Where are the preferences for the BOM Release Rule?
3. Is it possible to download the existing CHANGEABLE_PRE_RELEASE rule set?
Patrick Williams | Engineering Systems | o: 616.698.3766 | c: 616.947.2110
[cid:image003.jpg@01CD6F0F.C6F43C60]
*Correction* M010. M020 is not released yet.
[cid:image001.jpg@01CD6F10.158833E0]
If you look in <wchome>\loadFIles\ixbImport
There are several example files
[cid:image002.png@01CD6F12.EF0E7910]
This is the output from my "windchill version" command and a screenshot of what's loaded in the ixbImport directory. I do not have any business*.zip files. My 10.1 M010 system was upgraded from F000.
Support Support Installer
Datecode Release Number Release Id Sequence Display Label
M010 10.1 pdml.10.1.10.21 01 Windchill PDMLink 10.1
M010 10.1 wsp.10.1.10.21 03 Windchill 10.1 Service Pack
M010 Creo 2.0 vizpviewrun.10.1.10.14 02 Creo View - Clients
M010 10.1 mpml.10.1.10.21 01 Windchill 10.1 MPMLink
M010 10.1 whc.10.1.10.21 01 Windchill Help Center
M010 10.1 ptlc.10.1.10.21 01 Windchill 10.1 PartsLink Integration Client
M010 Creo 2.0 vizadapters.13.1.10.14 03 Creo View - Adapters
M010 10.1 ie.10.1.10.21 01 Windchill 10.1 Info*Engine
M010 10.1 esi.10.1.10.21 01 Windchill 10.1 ESI Services
M010 10.1 wlp.10.1.10.21 01 Windchill MultiLanguage Pack
M010 10.1 wnc.10.1.10.21 03 Windchill 10.1 Services
There are no patches installed.
Non-Default Locale Support:
Code Name
zh_TW
de
it
zh_CN
ko
fr
ru
es
ja
[cid:image003.png@01CD6F25.C5F2CFF0]
[cid:image004.jpg@01CD6F25.C5F2CFF0]
