Hi All,
As you are aware that in 12.0.1.0, Windchill DS is removed from the technology stack and only user information is stored in Active Directory or LDAP v3 compliant LDAP Server
PTC didn't give any preparation document for LDAP v3 compliant LDAP Server for Windchill
If any one of you tried, Please let me know your experience
I would like to know whether you have to do any configuration once you install the LDAP server before you install windchill
Best Regards
Prajeesh Kumar
I resolved the issue and I am able to install windchill sandbox with OpenDJ as LDAP Server for user management. You have to install OpenDJ and create atleast one organization and organization unit and then specify that while doing the installation
I actually missed this, probably because during the original 12.0.0.0 installation I had followed the recommendation in CS326880 to use the 11.2.1.0 version. Updating later on to 12.0.1.0 didn't complain about continuing to use this version...
For others who also missed this, here's a TS article talking about what to do going forward: CS335692
I am installing a new instance of 12.0.1.0 for sanbox purpose
I have installed the local LDAP v3 complaint server OPENDJ. While Running the PSI, we need to give the the Distingushed Base Name for users .
I have created a base DN o=ptc and created an organization unit ou=people
I gave the Distinushed base Name for users value as ou=people,o=ptc
I need to confirm whether this value is correct for installation
I'm struggling to get the LDAP settings correct in PSI.
What values did you put in for: Base Distinguished Name for LDAP Users?
It depends what you have created in OpenDJ, in my case would be:
ou=people,cn=AdministrativeLdap,cn=Windchill_12.0,o=ptc
I have given the values as same as mentioned by you in base distinguished name for LDAP users but installing the windchill getting database schema violotion error.
Pleas open a new thread for your issue with more detail of what you entered and where it is failing.
