2d drawings using Windchill mobile
jgronwick
3-Newcomer
Is it possible to view 2D drawings (.plt) using Winchill Mobile? If not, what is the best way to view .plt files from Windchill on an iPad?
sknox
(To:jgronwick)
right now we're looking at a custom cad worker to convert autocad to pdf. then place the pdf as the default representation of the object. WE're exploring this right now. DWG Converter - Batch Convert DWG to PDF,EPS,CGM,SVG,PLT,TIFF... due to the command line support. With any luck we should be done Friday.
mbarbosa
6-Contributor
(To:sknox)
Hi Steve,
I'm not sure if I understood, PTC will use DWG Converter?
