9.1 F000 PDMLink Workflow Task Comments
MichaelIbosh
All,
Has anyone figured out how to get the 'Assigned Task Default Comments' area string into a workflow variable in 9.1 F000 PDMLink? I'm working on converting my workflows from 8.0 M050 to 9.1 F000 and I need to get the string from the default 'Comments Area' in a assigned task, into a workflow variable so it can be used elsewhere in the workflow (like in emails sent from the workflow). What I'm looking for is a workflow expression that can be placed into a transition, that gets the text string and stores it in a workflow variable. Any help would be appreciated. Thanks ...
Mike Ibosh
I don't think it is any different from 8.0 M050. I would make sure the
activity has the record voting option checked. Then again, I don't have
9.1. But make sure that it is checked. Also look to see if the comments
are in the wfvotingeventaudit table in oracle.
_____
