9.1 to 10.1 Migration Question
MikeIbosh
7-Bedrock
All,
I'm pretty sure this is going to be a migration nightmare, so here is the situation.
Currently our production 9.1 M060 system HAS ProjectLink installed, and a couple of (deleted) test projects. They ended up not using PJL, and dropped support for that item. So now, when I download the software for 10.1, PJL is not available in the software download list.
QUESTION: Doesn't the target installation HAVE to contain the same modules as the source installation in order to migrate the database? Won't the migrator have a hissy fit when it sees that this module is missing from the target installation?
Mike
Yeah you will need to have ProjectLink on the new system you are migrating too.
[cid:image001.gif@01CD17C3.4F2E5330]
Steve Vinyard
Application Engineer
