A Role Description change in a Context Team needs to be propagated to the workflow team SetUp Particpants tab.
I change the Edit Role Description in the context team page for a Product.
I am then creating a custom CR that uses a custom workflow in that Product.
The new role description is not showing in the SetUp Participants applet for that instance of the workflow for that role.
How does the context team map that information to the workflow team instance?
When a role is added to a Product, Library, or Project a corresponding WTGroup row entry is made in that table.
The role description field is one of the fields in that row.
I can see the value in the field change after I alter it in the interface.
The context team role stops using the resource bundle information at that point.
Why does the workflow team that is created after the role description value change not use the updated information in the database field?
