ACL - to control the action in the state
AK_10813265
Version: Windchill 12.0
Use Case: ACL to create for removing the access for revise action
Description:
I wanted to remove the access for Revise action, once the Workflow reaches Part Attribute stage or any particular stage
First, review to see what ACLs are enabling the action. There are different approaches, but to me, it's more clear to remove the ACLs that are granting the unwanted access, then to create additional ACLs to deny it.
Hi Joe,
Thanks for you reply
But my question how to create an additional ACL to define when it in Attribute change task state,(screenshot attached below) any user should not be able to revise the WTPart which is in change process.
can you please step by step process, if that's possible...that would help for me
