We are happy to announce the new Windchill Customization board! Learn more.
API to read structure filter definition
HelesicPetr
Hello community gurus,
Have you ever found an API to get structure filter definition?
I haven't been successful.
I need to read the structure filter definition in my own table but I can not find any possibility to do it till now.
Any help or hint is appreciated
PetrH
you can have a look "NavigationCriteria" object and related methods:
Fetch Navigation Criteria:
NavigationCriteria navigationCriteria= NavigationCriteriaHelper.service
.getNavigationCriteria(filterName);
navigationCriteria.getConfigSpecs() and find the one with WTPartConfigSpec.
Cheers,
Xolomon
Hi @xolomon
Thank you for your replay.
I know the NavigationCriteriaHelper but I haven't found a way how to read actual user's settings from the Structure filter
I will check it tomorow. 😄
PetrH
Hi @xolomon
The NavigationCriteriaHelper.service can return saved filters. I can not find the actual settings which could be modified by user any time.
I can list all saved filters and get configSpecs for filter by name, but it is not what I need.
I would get actual settings that is read in a configure wizard. But I'm not able to locate where the filter specification is read and by what API.
PetrH
I just add a example
A custom table in custom tab should shows tree based on Structure filter, but I can not find a way how to get the settings of actual filter settings in the TreeDataHandler or TableBuilder.
as a workaround I use an own lifecycle filter but I would like to know to get the structure filter.
 PetrH
