AW: Tomcat gets high number of active sessions after restore of database
Regular Member
Stertz, Michael wrote:
> Thank you Jess and Prathap for responding.
> As noted under 2. PTC or custom code can easily produce such a problem
> - IT DID!
> Pure coincedence - at the same time with the database restore a new
> monitor was activated in the BigIP-Loadbalancer calling verify.jsp
> (aka LB keep alive) to check the operational state of the
> clusternodes. Unfortunately this script opens a new connection to
> tomcat every time it gets executed, which stays open after execution
> until timeout.
You will want to call a JSP that does /not/ establish a servlet
session. In recent enough versions of Windchill you can use:
