Activate WTPartDescribeLink being copied over from design view to Manufacturing view
PC_10805497
Version: Windchill 12.0
Use Case: We are using the bom transformer to create downstream manufacturing view from design view. We want that windchill copy over all related objects from the design view to be linked to the manufacturing view. Even if possible also takes over the calculated link from the drawing to the manufacturing view. I cannot find any instruction how to set this up?
Description:
Create new wtpart with view Design.
Relate described by and Refenced By document to the part.
Relate 3D file (EPM document) with owner link and drawing with calculated link.
Op part in bom transformation module.
Create downstream branch for the design view and create Manufacturing view.
All related objects should also be linked to the part with manufacturing view.
For EPM document this will probably with a content link as the model is linked with an owner link to the design view.
Regards Patrick
Fadel
23-Emerald I
(To:PC_10805497)
for calculated associations it is a dead end https://www.ptc.com/en/support/article/CS294758 .
for the other links you can configure the mpmlink.properties to copy over
Fede
Fadel
23-Emerald I
(To:PC_10805497)
Fede
