Add attachments to documents with loader process
Highlighted
Newbie
Hi all,
Does anybody know which xml-tags are used for adding attachments to documents using the OOTB loader?
I'm adding documents using this structure (in standardX05.dtd):
<nmloader>
<csvbeginwtdocument> ... <csvbeginwtdocument>
<csvibavalue> ... <csvibavalue>
<csvendwtdocument>... <csvendwtdocument>
<csvendwtdocument>
<nmloader>
I've found the tag csvContentAggregate which I insert inside csvEndWTDocument but I'm not sure if this will work.
Any suggestion?
regards,
Felipe
