Add items in the FMEA Worksheet form the FMEA Tree Items
JuanR_61021
Hi
I want to add in the FMEA Worksheet the item(s) that I have in my FMEA Tree Items tab.
For instance, once I have created my FMEA Tree Items (Functional or Components), I want to add them in the FMEA Worksheet below.
Is there a way to do it automatically adding all the FMEA Tree Items and not entering one by one?
Thanks in advance,
Juan
Hi @JuanR_61021
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • How are you currently adding FMEA Tree Items to the FMEA Worksheet? Are you doing it manually?
  • What specific attributes or data from the FMEA Tree Items do you want to automatically transfer to the FMEA Worksheet?
  • Do you have experience with Windchill customization or access to resources that can help with scripting and API usage?
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Windchill looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
JuanR_61021
(To:Catalina)
Hi Catalina,
Thanks for helping out.
I'll re formulate my question following the guidance provided.
Best regards,
Juan
I'm a new user of PTC Windchill and I'm running the version 11.0 of Windchill.
My goal using PTC Windchill is to generate Functional and Component FMEAs for a system.
I've learned so far how to create the System Tree Items and the FMEA Tree Items (Functional and Component), however, since a few weeks ago I'm stuck in a single point and I'm looking for help.
Once I have created the System Tree Items (Components/Functions), I would like to add them in the FMEA Worksheet to start fill up the data (Failure modes, effects, etc.) for the FMEA.
Does anyone know how to fill up the FMEA worksheet with the System Tree Items automatically? If there is a way to do it?
I mean, I have listed already the items in the System Tree Items section and I would not like to add them again one by one in the FMEA Worksheet section.
You probably have seen from me a couple of similar posts in the last 2 weeks and apologies for asking again. I went already through many support guides and I cannot find an answer that helps me out.
I've added a screenshot of the FMEA Tree Items that I would like them to "appear" in the FMEA Worksheet section. If my question is not clear enough, please contact me and I will re explain my issue.
Thanks in advance for your help,
Juan
