In Windchill 9.1, after checking out objects or simply adding them to a workspace, you were returned to the folder you were viewing before the add/checkout action. In Windchill 10.2 you are taken to the target workspace instead. Is there a preference, or some other way to restore the 9.1 behavior? Our users do not want to have to re-navigate to the product/library subfolder every time they add something else to their workspace.
Just to be clear, this is using the standalone browser. The embedded browser in Creo is used to view the workspace.
Thanks!
Tom,
It looks like this was an intended change, and there is no preference to specify which page it should redirect to after the add to workspace completes. There may be a way to customize this, but it's not doable out of the box.
