Adding a NonVersion Attribute to WTDocument
VR_13503348
I am using Windchill Aerospace & Defense Release 12.1 and Datecode with CPS 12.1.0.1
We need to flag the WTDocument with Compliance ready/ Approved/ Rejected without iterating/ revising the WTDocuent. How can we do that ?
Tried to Add a non versioned attribute to WTDocument Master . However , that is not visible to user in UI
Fadel
23-Emerald I
(To:VR_13503348)
We can Create and alias attribute on wtdoc referencing master attribute but it will be exposed to the edit layout which will iterate the doc :
Second option is to customize the rename document wizard to add the master attribute  .
Fede
TDT
(To:Fadel)
Hi @Fadel,
In the first option the attribute can always be removed from edit layout right?
Fadel
23-Emerald I
(To:TDT)
yes , later on we can remove  attribute from layout
Fede
