Addtional Sequences: WC 10.2 M010. SQLPLUS error.
pstapler
3-Newcomer
Trying to execute sqlplus in a Windchill Shell so I can create a custom sequence using the string bellow.
exec wtpk.createSequence('seq_name',start_num,inc_value).
Getting error: sqlplus  is not reconized as an internal or external command.
Patrick
BineshKumar1
(To:pstapler)
It should be the PDMLink credentials. Refer to wt.pom.dbuser in WT_HOME/db/db.properties
Thank you
Binesh Kumar
Barry Wehmiller
10 REPLIES 10
BineshKumar1
(To:pstapler)
It looks like you don't have oracle client is not installed on Windchill server. Download the oracle client, update the tns entries for windchill database and try again.
Thanks you
Binesh Kumar
Barry Wehmiller
I don't see that as an option from the PTC website.
BineshKumar1
(To:pstapler)
You can download the oracle client from Oracle website.
Another option is to run it from the db server directly. From the db server, logon to SQLPLUS and run the command.
Thank you
Binesh Kumar
Barry Wehmiller
I get the same error when I run sqlplus from the command line. So I never get to login to the DB. I can login and conencto the DB using SQL Server Manager.
BineshKumar1
(To:pstapler)
It looks like you are using SQL Server and the steps you were trying was for Oracle. Please follow the CS https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS42301 for SQL Server
Thank you,
Binesh Kumar
Barry Wehmiller
Thank you for your help so far. I think I am almost there. When I run the db command from the Windchill Shell I get
Warnings: 0
Errors: 1
I guess I'm not sure on the last part of the command line <schema_user> <password>. Is this the sql admin UN/PW or the PDMLink credentials or the Cognos credentials?
pstapler
3-Newcomer
(To:pstapler)
Well I got that figured out. I works with no username and password.
New problem is it starts everything with 730000. I replaced 730000 with 01 in my sequence file. So I don't know why it starts at 730000.
pstapler
3-Newcomer
(To:pstapler)
(dummy CHAR(1), value BIGINT IDENTITY(01, 1))
BineshKumar1
(To:pstapler)
Thank you
Binesh Kumar
Barry Wehmiller
Restarted WC and it works. Thanks again.
