After rehost, Apache shows running but does not show "It Works" in Web Browser
ChristineVick
6-Contributor
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.11
I am trying to rehost from a RedHat v7 system to a RedHat v8 system and Apache shows as started but will not open and neither will Windchill.
Hi @ChristineVick
I would start with a telnet to control if the port is opened.
PetrH
checked and port is open
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 3361011/httpd
So apache works.
"It works" is returned by apache so I would check the connectivity between the browser and apache.
PetrH
Hello ChristineVick,
Did you try to enable DEBUG logs ?
KR,
Charles.
