AfterLoader installed, viewables no longer generated on check-in
Aaronm87
I recently installed after loader, but I noticed that the viewables are no longer generated on check in. Clicking the visualization window publishes a viewable with the desired attachments with no errors. How do I get this to occur at check-in?
publish.service.documents.checkin.enabled=true
publish.afterloadermethod=com.ptc.wvs.util.AfterEDRloader/copyToEPM
publish.afterloadermethod.copyToEPM.Filext=pdf dwg igs stp
Aaronm87
(To:Aaronm87)
After some digging, I found the cause. Posting this here in case anyone else has this issue.
The publish-riles.xml should contain the property
<publish additional-files="standard_files" on="checkin"/>
The initial setting from the documentation has it set to "create-representation".
Aaronm87
(To:Aaronm87)
