Allow custom role to manage templates
TamasBiro
Is there a possibility to enable the "Template" section under a product for a non-administrator user with a specific role, so that he can create/show/hide (Document, CAD Documents Life Cycle etc.) Templates.
Thank you,
Tamás
LoriSood
23-Emerald I
(To:TamasBiro)
Hi Tamas,
Only context managers (product/library/project managers)/orgadmins/site admins can see the tab OOTB.
doehr
(To:TamasBiro)
Hi there,
Probably not. The only setting I can find anywhere related to Templates access is in Profiles, where it has the option "View Templates page on Organization tab". Even on a dummy account that I temporarily gave Full Control All on a particular type of Template, the menu didn't show up. It looks like that Profile setting combined with being at minimum an Organization Administrator is what is required; nobody gets access to the Organization tab with all those utility menus without being an Org or Site Admin.
Daryl
LoriSood
23-Emerald I
(To:TamasBiro)
Hi Tamas,
doehr
(To:LoriSood)
So THAT's where the coding is through the server? Even when no other access of any kind whatsoever is given to that context role in the Policy Administrator?
Wow. That is super subtle and not really necessary. I also see that putting someone who otherwise doesn't have admin access in that role shows Information Structure, Publication Structures, and Utilities. So plopping someone into that role to get them access to Templates also gives them access to over a dozen fundamental system administration functions that they likely should never, ever have access to.
This isn't a good way to set up the system.
