Allow users to see other users's new in workspace (but uploaded) document
AdrienKLEIN
Hello everyone,
I would like to know how I can allow users to see documents that are new in other users workspaces (after it is uploaded of course)
The aim for the user is to see what references are already created in order to name their new parts.
Thank you!
HelesicPetr
(To:AdrienKLEIN)
Hello @AdrienKLEIN
I've found solution for you.
Administrator has to grant ACL rule Read for EPMDocument on the user Domain. If you need WTPart grant same rule to wtp.
I recommend to grant it on organization level.
Allow read ACL is enough
result
There is consequence a user can access and just see other users workspace metadata
PetrH
6 REPLIES 6
HelesicPetr
(To:AdrienKLEIN)
Hi @AdrienKLEIN
This is general function of Windchill.
Only administrators can see the other user private workspaces.
There for you can just add users to admin group
PetrH
Thank you for your answer @HelesicPetr .
Of course I can't and won't make all the users admin. Some of them just told me it was possible before (I forgot to tell we run 12.0.2.1, and migrated from 10.2).
Just to eliminate all doubt : I don't want the user to see other user's workspaces, I just wish a user is able to see, with a search in commonspace, the uploaded new CAD from other users.
Only purpose for them is knowing a reference is already reserved or not.
You could try to use the report described in this article
https://www.ptc.com/it/support/article/CS20630
Here you will find a list of reports, divided into several sections, including one devoted to EPMDocs
Article - CS328887 - [Knowledge Hub] Windchill PLM Query Builder Reports (ptc.com)
Here another document with lots of report ready to use
Resource for reporting - PTC Community
Marco
HelesicPetr
(To:AdrienKLEIN)
@AdrienKLEIN
I just add that there is ACL rule that can be added to a users and thanks that they can see the new objects in other user workspaces.
I don't remember what rule it was.
PetrH
HelesicPetr
(To:AdrienKLEIN)
Hello @AdrienKLEIN
result
PetrH
Wow it works! I hope ther won't be any bad side effect.
If any, I will tell here.
Anyway thank you very much to all of you, and especially @HelesicPetr , that was exactly what I expected!
