2 new articles on PTC dealing with issues with Amazon Corretto 11.0.20 and 17.0.8
https://www.ptc.com/en/support/article/CS397632
https://www.ptc.com/en/support/article/CS397375
I just tried 11.0.20.8.1 on a test Windchill 12.1.2.2 server and I also have this issue (CS397632) of Windchill failing to start. I don't have a Windchill 13 install to test. I have not tried running a PSI solution either with this.
On my laptop I can also vouch that upgrading the java from Amazon Corretto 17.0.7.7 to 17.0.8.7, that my Eclipse sees that it has many "can't find class" errors. Downgrading from 17.0.8 back to 17.0.7 fixes the Eclipse issue.
Amazon corretto has updated 11.0.20.8.1 to 11.0.20.9.1 which fixes this issue for me. I also note that 17 has been updated from 17.0.8.7.1 to 17.0.8.8.1. My guess this same bug has been fixed in 17 also although I don't have Windchill 13 to test it on.
I check change log in github and saw no mention of anything related to Apache Ant.
