Hi everyone,
I have a pdf file in winchill. I put some note and mark ups, after that I save it.
I want to know where is the annotation set save file path? how/where to open that in windchill.
Thank you,
Luar
Hello Luar,
You will get all your annotations saved from the Representation / Annotations options
In case if you have not enabled this option, then please follow the below steps
1. Search for the relevant object
2. Click on + button to add a New tab1,
3. Click on Customize button and then select General --> Representations / Annotations
Once you enable this option, all information related to Representations and annotations will be available
Athmanand
Hello Luar,
Athmanand
Hi Athmanand,
Thank you! now I know where the annotations saved.
Luar,
