I am a primary Pro/E user, but I'm trying to get up to speed on SolidWorks. On my XP 64bit system, if I open SolidWorks, the WGM opens but will not connect to the CAD application. If I open the WGM and login, then open SolidWorks everything connects.
On the other user's PC setups, they don't have this issue.
Any suggestions?
Thanks, Kathy
would be worth removing the application registration in WGM and re-registering.
Also make sure you have the following env variable set correctly; PTC-WLD_ROOT to keep you Pro/E and WGM worksapces seperate.
Cheers
Simon Lucas
In Reply to Kathy Richardson:
Any suggestions?
Thanks, Kathy
