Anyone have a way to find nested family tables? Ideally a query builder report with criteria = Is Generic and Is Instance. But I can't figure out how to do this.
Hi Mike,
This might help you: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS29111&source=Case%20Viewer
Shirish
Mike Lockwood you can refer to KB article https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS118348 and use 3 in family table status field to search for nested family tables.
I hope this helps you.
Best Regards,
Shirish
Got it - we have 161 each to deal with.
Rather than put in the customization suggested, a very simple query builder report can be used. The key is the criteria familytablestatus =3.
thanks
Mike,
it's possible for you to attach a sample of your query builder to this discussion?
Query builder report attached - see Description comment
