Hi Patil,
Check the log format defined in your httpd.conf file. If you haven't
changed it, here is the PTC custom format
LogFormat "%h %l %u %t \"%r\" %>s %b %D" custom
b - Bytes sent, excl. header
D - Resp. time in microsec
Prathap
On Fri, Apr 24, 2009 at 4:28 PM, Prashant Patil <
-> wrote:
> Apache Gurus,
> Here is sample extract from the access.log file, Can you please let me know
> what does the below line tells
> "POST /Windchill/servlet/SimpleTaskDispatcher?CLASS=com.ptc.windchill.uwgm
> HTTP/1.1" 200 46984495 435375000
> The figures "46984495" & "435375000" what do they indicated whether
> metadata size or the physical file content size.
> Regards,
> Prashant K. Patil
> 901-252-5032
