I will have to check my notes about this, because it has been a while since I worked with Aphelion, but I think that the user/password that must be used to log in to the Aphelion Web Tools page was not the LDAP Administrator (cn=Manager)... I think that it should be an Operative System user/password assigned to a specific group...
Iker Mendiola
Prambanan IT Services
http://www.prambanan-it.com
Iker Mendiola - Prambanan IT Services |
Ok, I have found it:
After initial installation, you must satisfy the following requirements to log in to the Web interface:
• Must have a valid username and password defined on the host machine.
• Must be a member of the LDEadmin group (the group name is case-sensitive).
If you are not a member of the LDEadmin group, contact your administrator.
The user and group must be in the Operative System, not in Windchill or LDAP.
Iker Mendiola
