Applet on Windchill 7.0 with HTTPS and Reverse Proxy
Newbie
Has anyone got Windchill 7.0 running with HTTPS and
Reverse Proxy setup, with all applets working?
I am facing a problem in this setup - the Workflow
Task Content applet (for adding removing attachments
to the Task).
The Task Content Applet fails with
sun.plugin.cache.DownloadException followed by
java.lang.StackOverflowError
Since it is R7.0, I have to use Java plugin 1.4.2
I have done HTTPS and Reverse Proxy settings as per
the Windchill Install and System admin guides and TPI
130548
https://www.ptc.com/appserver/cs/view/solution.jsp?n=130548
The client plugin (1.4.2) settings include:
-Djava.protocol.handler.pkgs=HTTPClient
-Dwt.boot.socketFactory=wt.boot.WTRMIHttpToCodebaseSocketFactory
All other applets don’t seem to have any problem, but
this applet fails.
Anybody knows the solution, kindly help me. If you
need to know more, I will be glad to share more
details.
When I googled, I found following bug, reported 2
years back and not resolved yet.. sure it must have
hit someone in Windchill community.
http://bugs.sun.com/bugdatabase/view_bug.do;:WuuT?bug_id=4845728
Thanks & Regards,
Nilesh
Re: Applet on Windchill 7.0 with HTTPS and Reverse Proxy
Well, the mailing list won't allow the presentation to be attached due
to length. Given the 50K length limit, interested parties will have to
get the information another way.
Jess Holle
Jess Holle wrote:
> Nilesh Bari wrote:
>> Hello,
>> to the Task).
>> 130548
>> this applet fails.
>> details.
> I have heard of exactly one occurrence of this issue -- and for that
> customer it only occurred on some client machines and not others.
> Unfortunately, this was some time back and I cannot seem to find
> further details again at this point.
> If you're on R7 M040 or higher, you may wish to try settings along the
> lines of those on slide 5 of the attached slide set (which use the
> latest Java Plug-In installed on a client rather than requiring a
> specific Java 1.4.2 version) and then try Java 5 on one of the
> problematic clients.
> Java 5 client support is not official until a later R7 M060 and there
> were some fixes therein to address issues specific to use of Java 5
> with Windchill. If Java 5 addresses the issue in testing, I would thus
> suggest moving to M060 or later (e.g. M070 while you're at it if
> you're not already at M060).
> Jess Holle
Hello Jess,
Thanks a lot !! You just made my day 🙂
Fortunately we are at R7.0 M060 and so I could use
Java Plugin version 1.5.0_06 which resolved this issue
We had earlier tried using latest 1.4.2 plugin
(1.4.2_11), which did not help.
This isssue is only resolved by using pluin version
1.5.0 (I directly tried the latest one: 1.5.0_06).
NO errors in the java console while using the Task
Content Applet !!
I also observed appreciable performance improvement
for all applets using plugn-1.5 ... don't know if this
was because only few of us were hitting the server on
May-1st holiday..
Thanks & Regards,
Nilesh
--- Jess Holle <-> wrote:
> Nilesh Bari wrote:
> > Hello,
> and
> > to the Task).
> per
> TPI
> > 130548
> but
> > this applet fails.
> > details.
> have
> -- and for that
> and not others.
> seem to find further
> settings along the
> (which use the
> than requiring a
> one of the
> R7 M060 and there
> to use of Java 5 with
> I would thus
> you're at it if you're
> Jess Holle
Nilesh Bari wrote:
> Hello Jess,
> Content Applet !!
> May-1st holiday..
The Java 5 Plug-In *is* faster overall.
Also, we took steps to reduce some of the overhead built into RMI in
M050, though you'll only see this benefit when the boot.jar is installed.
Jess Holle
