Apply check-in failure option to family table unverified data
SB_10959022
3-Newcomer
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS18
About Family Table parts,
It is managed according to the process of [check out - Generic modification - Verify - Check in].
Among these processes:
I would like to know how to process PDM check in - Fail when the Verify step is omitted by user mistake.
Currently, Check in is possible even if Verify has not been completed (completely or partially unverified).
I would like guidance on how to limit this.
Translated the text from Korean to English using google translate
Subject: 패밀리 테이블 미 검증 데이터에 대한 체크 인 실패 옵션 적용
Body: Family Table 부품에 대해,
[check out - Generic 수정 - Verify - Check in] 의 프로세스에 따라 관리하고 있습니다.
이러한 프로세스 중,
사용자 실수로 Verify 단계를 누락하였을 때, PDM check in - Fail 처리하는 방법을 알고 싶습니다.
현재는 Verify 가 완료되지 않더라도 (전체 또는 일부가 미 검증 상태) Check in 이 가능합니다.
이것을 제한하기 위한 방법을 안내받고 싶습니다.
- By Community Moderation Team
6 REPLIES 6
Hello @SB_10959022.
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
Thanks.
I asked this question,
one is PTC case create
the other is PTC community.
I recieved reply from PTC technical engineer yesterday.
reply : There is no solution to check in rule control about has been not verify family table data.
This is what i want to know,
I have finished Edit Family Table data, but It has been not Verify.
At this time, Drawing (*.drw) data is diffrent from 3d prt.
I'll trying to PDM Windchill Check-in, then It is able to check in (= check in success).
Inspite of Family instance has been not verifying yet.
I want to konow how to
'If family table data has not been finished verify then Check in is Fail.'
The best available solution might be: config.pro option verify_on_save_by_default=yes
See: https://www.ptc.com/en/support/article/CS62074?source=search
Thanks for your suggest.
Sorry but, I dot't want auto verify when save process.
My instance has many quantity so it is spent very long time for verify.
I want only one time verify before Server check in.
I want to know, 'How can I make (control) Unverify Family table data can not be able check in to PDM Windchill.'
Hello @SB_10959022
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
I haven't meet correct solution yet^^.
