Happy New Year all!
I'm testing the Architecture Editor in Windchill 12 (according to Managing the Positioning Architecture in Architecture Editor ), and out of curiosity, wanted to delete a node from the graph.
I do not get the Right click to delete neither a node, nor an interface, as it says should work. ("To delete a node or an interface from the graph, click the node or the interface and select the Remove right-click action.")
Tried in two different browsers (Chrome). Right click just brings up the usual menu from every web page. I have no extensions installed on Chrome.
Any ideas?
Zoltán I can't reply directly to your question but you could follow the PTCU LEARN Windchill: What's New in PLM course it contains a practical exercise about dynamic positioning where the architecture editor is used.
Hope this helps.
I can't find anything in PTCU on this. Searched for both "architecture editor" and "What's New in PLM" in "All Windchill" even. However, I know how to right click on the link, but don't get the right pop-up
Ah, training class... OK, got it. Thanks, but not what I need here unfortunately.
@Zoltán it is easier to contact PTC support directly then try to attendee the class.
Hi @Zoltán
OOTB the first try works as I expected in the chrome browser.
In your screen there is different type of link I guess.
What version of Windchill do you use?
my example
PetrH
Hi Petr,
Release: 12.0.2.0.
If I can add link, I should be able to remove too.
I must assume the problem lies in the browser(s). But even Edge won't work for me. My Chrome is virgin, I never use it for anything, and have no extensions.
In Google Sheets it works, I don't get the standard "Open in new TAB", etc. but the proprietary right click menu with the Sheets commands.
OK, just got it verified from support, in 12.0.2.0; the RMB is not working, this issue is fixed in 12.0.2.7.
