Architecture Editor - delete a node or an interface from a graph
Zoltán
Happy New Year all!
I'm testing the Architecture Editor in Windchill 12 (according to Managing the Positioning Architecture in Architecture Editor ), and out of curiosity, wanted to delete a node from the graph.
I do not get the Right click to delete neither a node, nor an interface, as it says should work. ("To delete a node or an interface from the graph, click the node or the interface and select the Remove right-click action.")
Tried in two different browsers (Chrome). Right click just brings up the usual menu from every web page. I have no extensions installed on Chrome.
Any ideas?
HelesicPetr
(To:Zoltán)
Hi @Zoltán
My version is 12.0.2.7 so the 12.0.2.0 can have a bug in your case.
PetrH
9 REPLIES 9
jlecoz
(To:Zoltán)
Zoltán I can't reply directly to your question but you could follow the PTCU LEARN Windchill: What's New in PLM course it contains a practical exercise about dynamic positioning where the architecture editor is used.
Hope this helps.
Zoltán
(To:jlecoz)
I can't find anything in PTCU on this. Searched for both "architecture editor" and "What's New in PLM" in "All Windchill" even. However, I know how to right click on the link, but don't get the right pop-up
jlecoz
(To:Zoltán)
Zoltán
(To:jlecoz)
Ah, training class... OK, got it. Thanks, but not what I need here unfortunately.
HelesicPetr
(To:Zoltán)
@Zoltán it is easier to contact PTC support directly then try to attendee the class.
HelesicPetr
(To:Zoltán)
Hi @Zoltán
OOTB the first try works as I expected in the chrome browser.
In your screen there is different type of link I guess.
What version of Windchill do you use?
my example
PetrH
Zoltán
(To:HelesicPetr)
Hi Petr,
Release: 12.0.2.0.
If I can add link, I should be able to remove too.
I must assume the problem lies in the browser(s). But even Edge won't work for me. My Chrome is virgin, I never use it for anything, and have no
extensions.
In Google Sheets it works, I don't get the standard "Open in new TAB", etc. but the proprietary right click menu with the Sheets commands.
HelesicPetr
(To:Zoltán)
Hi @Zoltán
PetrH
Zoltán
(To:HelesicPetr)
OK, just got it verified from support, in 12.0.2.0; the RMB is not working, this issue is fixed in 12.0.2.7.
