As Stored Drawing References
TomU
Can someone please clarify how I list the 'as stored' version of a drawing's references?
For assemblies I can use the structure browser. For drawings the only thing I'm seeing is the References section of the Related Objects tab. Unfortunately this only shows the Latest Version.
I can manually add the drawing to a workspace with the config spec. set to 'as stored'. There has to be a way to display this without adding to workspace.
This is with Windchill PDMLink 10.2 M020. Thanks.
TomU
(To:TomU)
Found it!
I was sure I could do this in 9.1. So sure I went back and fired up our old system just to remember how. It was the "Relationship Report" tab.
Take a look at the attached pictures. Notice how, when using the 'as stored' config spec., each drawing version lists is corresponding model version.
It still exists in 10.2, but has to be manually added to a new tab. It's not visible by default out of the box.
5 REPLIES 5
LoriSood
23-Emerald I
(To:TomU)
You may be able to do this using an I*E task. An example one may be found here:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS167152
TomU
(To:LoriSood)
No offense, but really?!? I can't see what version of a object is tied to a particular drawing without writing custom code?
LoriSood
23-Emerald I
(To:TomU)
I understand.... It would make a good Idea!
TomU
(To:TomU)
Found it!
LoriSood
23-Emerald I
(To:TomU)
Ah.... I'd forgotten about that report! It's been ages since I've had to look at it. Well, I'm glad there's an easier way to do it than the I*E task!
