Attach Documents in Workflow process
RavinKayasth
Hey Gurus',
I have a requirement, where the Reviewer / Approver needs to attach some form of document to the workflow task which is Review / Approve.
How do I achieve this?
Thanks & Regards
Ravin Kayasth
Project Lead
Wipro Technologies,Bangalore
' (91 80) 4135-2036
* Ravin.Kayasth@wipro.com
Please do not print this email unless it is absolutely necessary.
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s) and may contain proprietary, confidential or privileged information. If you are not the intended recipient, you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately and destroy all copies of this message and any attachments.
WARNING: Computer viruses can be transmitted via email. The recipient should check this email and any attachments for the presence of viruses. The company accepts no liability for any damage caused by any virus transmitted by this email.
www.wipro.com
5 REPLIES 5
There is a link (Task Content) in the task itself to do that (in the link group at the bottom-left). But all the documents uploaded this way will be attached to the Workflow Process object, instead of being attatched to the object running the workflow. So, take care with this if you are using vaults, because the workflow process' attachments could be stored in blobs instead of vaults.
Iker Mendiola
Prambanan IT Services
http://en.prambanan-it.com
http://www.prambanan-it.comIker Mendiola - Prambanan IT Services
Thanx Iker,
So what is the way to attach this to the object running the workflow?
Or alternatively, is there a way to store it in the vault instead of the BLOB?
Thanks & Regards
Ravin Kayasth
Project Lead
' (91 80) 4135-2036
If you upload it to the workflow through the Task Completion UI/workitem, I
believe the workflow has its own notebook, a content holder. You'll have to
establish a way to get to the content from there, download it to a temp
directory and then get to the PBO of the workflow (which if it too is a
contentholder), and reupload the the content attaching it to the PBO. After
completion you can go back and remove it programmatically from the workflow
notebook/content holder. I have done this before and can give pointers -
just cant share any code.
David DeMay
_____
Clearly not an elegant solution, but there is an ongoing need.
We would also very much would like PTC to address this.
A few specific use cases are:
- During a promotion request approval routing, would like users to be able to upload a file. Can't attach to a Promotion Request object, and can't attach to any objects being promoted without iterating them, making them stale for promotion.
- During a ProjectLink document routing, (pretty much same as above).
Using a discussion forum posting is another way to attach a file and we use that at times. You can in fact use Discuss for both cases above. The problem is that there is no visible flag or indication that a Discussion Posting exists. Users have to navigate to there to see. A flag of some type (different icon possibly would be best) may be the best.
You can add a column to your Folder Table Display for Discussed. This
will show an icon for discussed items. There is also an OOTB display
called Discussed.
Steve D.
Quoting "Lockwood,Mike,IRVINE,R&D" <mike.lockwood@alconlabs.com>:
> may be the best.
