Attribute related information from Windchill in XML file
AJ_10616560
3-Newcomer
When converting excel file into XML file, under Attribute definition there are few information in converted XML file which is not in excel. Are they static and what are those tags refers to?
Fadel
23-Emerald I
(To:AJ_10616560)
Generally the the first tag should have the quantity of measure for real numbers with units  like
<csvQoMName>Length</csvQoMName> , in case of loading Options (O&V) this is required only for numeric options
when specifying above , the second tag can hold units for each measurement system like below
 <csvnameValuePairs > CGS ~ cm|MKS ~ m| SI ~ m|USCS ~ in </csvnameValuePairs >
Fede
Fadel
23-Emerald I
(To:AJ_10616560)
Fede
