It's so slow and there's no feedback at all.
Purging 2 months of logs and has been running for 8hrs now, there 5 years to purge.
The only way that I know of to monitor progress is to query the number of rows in the AUDITRECORD table - which can be done while it's running.
Agree that there should be some progress feedback - possible that it's stuck.
yeah it was stuck, thanks you're a legend
What do you need to do if & when it's stuck..? 😄
Try to stop it using windchill wt.util.jmx.SMJconsole or else restart the MS. The cause was missing indexes in my case
I restarted 'everything'... users started reporting the system is not responding.
Yet another doomsday tool this Audit Log Purge 😁
