Same observation here. Nothing I can see in preferences. I did see that it was somewhat sticky in that I moved to another tab and it remained expanded. I use Tree view as well. However, when I returned sometime later, it was collapsed again. I would submit and idea. I also could not find anything in knowledge base.
Thanks @avillanueva, I will be creating one in a little. To click once is one too many times... 😁
