We are in 10.1 In order to believe OIR is driving that value, you have to modify ootb oir and have following contents in place of number attribute. I would recommend you to try creating new oir for epm at product or library level.
<attrconstraint id="number" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints"> <value algorithm="com.ptc.core.rule.server.impl.GetServerPreGeneratedValue"/"> </attrconstraint>
I am expecting Name pattern following PRT000X for Part ASM000X for Assembly when you are not connected to Windchill server. I know this is not your question, so ignore this additional note.
Ayyappan
David:
We are using 10.1 and we see this when we create new files. I recall that before our Windchill was set up to make Name, NUMBER and filename the same by default, there was a system generated number in this space.
Andrew Mansfield
KI
Green Bay, WI
In Reply to David Haigh:
I'm testing out a 10.2 upgrade from 9.1. In Creo I'm seeing this. Which we didn't have before. Is this OIR's or some other setting?
[cid:image001.png@01CFD805.3FC169F0]
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
