Auto numbering for both CAD centric and Part centric approach
Dobi
I'm playing around with auto-numbering in my dev environment.
For most things in production we'll do a File/New in CAD and then auto-associate/create new WTPart on checkin. That works just fine.
For some cases, we'll create the WTPart first (or have a manufacturing view).
In auto-numbering with the part-centric approach, if I create a new WTPart and check the "Create CAD" box both end up having the same Number value based on my sequence and naming. So that works fine.
Keeping the same rules in place, File/New (in NX) creates the correct next in sequence number to replace the file name on save (from Help Center). On upload or check-in though, the auto-associate to create a new WTPart generates the new in sequence value for the Number. The name is fine (same as CAD).
This appears to be OOTB expected behavior (Help Center )
Is there a way to turn off auto-numbering for WTParts when the CAD is creating it via auto-associate (CAD centric approach) and have it be on when WTPart is created standalone or with associated CAD (Part centric approach)?
Is this a "novel" ask? Seems like you'd want an easy "oh, you're creating a Part first with CAD --> here's a number for both" and "oh, now you're doing CAD first... here's the WTPart that matches the number" option.
There was this from about a decade ago. If this is still accurate, that means there'd need to be 2 part types each with it's own OIR. One has autonumbering turned on (the soft type) and the other (the root type of WTPart if OOTB auto-associate) has it turned off.
Does anyone else run auto-numbering in this fashion? Is this the only way to go?
Hari_Vara
(To:Dobi)
Please check the preference called "Part Number Attribute" in EPM Build section , as much as I could recall.
This is nothing but to communicate to Windchill to use this Attribute from the EPM Document (CAD Document) to number the WTPart when created from a EPPM Build (Auto Associate / Edit Associate).
Having the above in combination of Auto Numbering for WTPart, I think you can achieve your result.
Cheers
Hari
Dobi
(To:Hari_Vara)
I'm having trouble finding that particular preference.
In the EPM Service Preferences I have all attributes publishing the the parts.
In Operation/Auto Associate there is a "Force Autonumbered Part Creation" preference that's set to no. As I read this, it ought to meant that the part would - on auto-associate through check-in - get created based on the CAD number. This seems to be in direct conflict with OIRs if you have autonumbering on WTParts.
Unfortunately, that's not my experience and the 2 softype method seems to be the correct solution. Just need to test this with the correct type to be auto-associated.
This
