I'm trying to transfer parameters defined by block names defined in AutoCAD to Windchill, by using WGM for Windchill 9.0. However, I can't figure out how to map the attributes from AutoCAD to parameters in Windchill. To do this for custom parameters defined in AutoCAD by navigating the File -> Drawing Properties -> Custom menu is ok, but not for parameters defined by block names. Some help would be much appreciated.
