AutoCAD drawings in Intralink 3.4
Highlighted
Participant
When we were using Intralink 3.3 I defined a new object type "AutoCAD
Drawing" and imported 1000's of AutoCAD drawings into Intralink.
In 3.4 PTC added a new default object type "DWG" for AutoCAD DWG files.
This object type is now automatically used by Intralink whenever I add new
AutoCAD dwg files to Commonspace.
I'm also starting to get some other conflicts having both of these defined.
Has anyone dealt with this already?
I would like to have just 1 type defined, which would have to be "DWG"
since it's now the standard one.
I suspect an SQL script changing the object type from "AutoCAD Drawing" to
"DWG" for all the original files would probably work, but I was hoping
someone out there might have some advice before I consider messing around
with something like that.
Highlighted
You need to modify all of your AutoCAD to one reference, and delete the
second one from the Intralink Object Types.
This really messed me up because I ended up with multiple definitions
for excel workbooks when we updated to 3.4
Black & Decker Hardware & Home Improvement
Michelle McMasters
Engineering Systems Administrator
michelle.mcmasters@bdhhi.com
Demonstrate Unyielding Integrity * Deliver on Commitments * Inspire
Excellence * Win through Teamwork
IMPORTANT NOTICE: This message is intended only for the use of the
individual or entity to which it is addressed. The message may contain
information that is privileged, confidential and exempt from disclosure
under applicable law. If you are not the intended recipient, you are
notified that any dissemination, distribution or copying of this
communication is prohibited. If you have received this communication in
error, please notify the sender immediately. Thank you
