AutoCAD files in Intralink
Participant
I'm looking for some practical advice on using Intralink (3.3 currently) to
manage AutoCAD drawings.
I want to consolidate all of our design drawings under one single file
management system
I've set up a definition for AutoCAD drawing files in Intralink
Administration Object Types:
Name Convention Description Launch Command
View Command
AutoCAD Drawing *.dwg AutoCAD Drawing noversion.exe $ACAD #FILE
and have defined the $ACAD environment variable with the path of the
AutoCAD executable.
I wanted to import some files into a workspace but when I selected some
older files, they showed up as Typedef "-- Not Found"
How do you handle upper case filenames properly?
I've been poking around the knowledge base a bit but haven't uncovered
anything about this yet.
Any other tips would be welcome..
