Patrick,
I believe this solution works only if the project member has access rights to the library where the component is located.
Sometimes exporting to a project is used to show part of the library to project members who should not have access to the full library ?
Vincent
In Reply to Patrick Kurtz:
Jared -
One quick way to solve this, is to create a document in the project as a URL
content. Then, in that URL content, add in the URL from the Library
document. This way you won't ever have to update anything because the
latest will always be downloaded from every project it's added.
Patrick Kurtz
Services Delivery Manager
ProductSpace Solutions Inc.
"Your Products to the Nth Power"
630.495.2999 Ex 8110
