Good day
I am new to Windchill and I have created some baselines and added objects to these baselines.
I would like to find out how I can create a report, which tables and joins and select or constraint that I should use to show/list all objects added to a baseline.
Mark
Below three query builder on baseline ready to use.
Report on EPMDocument Shared Status to Project through Managed Baseline
Report to get the Document Structure and add Filter from Baseline
Report to list the WTParts/checked out WTParts in the baseline
Thank you very much for these examples, I will definitely look into them however all I really need for now is a simple report that shows the Baseline and what documents, objects or parts are related to that Baseline.
You have to connect Baseline with all the objects (tables) you would expect to find related.
Just tried on my system.
