Good morning David,
Our company isdoing exactly what you asking for with our lifecycle process. Creating a custom lifecycle that prevents documents from being modified upon promotion request can be tedious.This is based on Windchill 9.0/9.1.
1.Lifecycle states - If your companyrequiresspecific standards with state names that aren't provided out of the box inWindchill, you will need to create custom states. If not, life will be one step easier.
Note: The Lock transitiondoes NOTguarantee that the object is read-only. You will most likely need to set permission to on the lock state(i.e. 'Pending') via Policy Administrator to ensure that the object type is read-only.
Overall, it's not a walk in the park especially on a system that's been around for some time.
Give me a call when you get into office. In the meantime, I'll see if I can work up a how-to document with more details.
