Hello All,
Can any one suggest me a solution,where I want to block the Set-State featue of a WTDocument object when WF for the WTDocument is active.
Sriram
Hey Dave,
You don't need any customizations for this. This is now standard in Windchill 8 to 9.1 with WF transitions. You have to remove the transitions of set state for certain roles. The admin is usually the one who can set state to released while the author can set state from in work to under review and revise from release to in work.
