Bridge PLM / ERP
Remy25
Bridge PLM / ERP
Dear all,
I'm actualy start a new manufacturing project, and I whant transfere PLM information's to ERP, and I need some help to finish corectly my project.
Can you share me your feedback concerning the communication between PLM and ERP?
PTC has a tool to do this ? if yes do you know the name?
Or, if PTC haven't tools, and if I need external source, can you give me which bridge (or integrator) have you used to do this?
How far have you send the informations (CAD / Article / BOM / MBOM / Process Plans / Instructions etc...)?
6 REPLIES 6
GAINSREENI
6-Contributor
(To:Remy25)
Yes, PTC has a solution called ESI ( Enterprise Systems Integration ) which supports Windchill and SAP, and Oracle Application integration only.
it's ready to use solution.
and another one WEBridge also a good solution that will support windchill and any other ERPs ( SAP ECC6, SAP S4Hana, Oracle Apps, SAP B1  etc) integration.
regards
GAIN Sreeni
Remy25
(To:GAINSREENI)
Hi Sreeni,
Thanks for your feedback.
What is the difference between your solution and PTC's solution ?
GAINSREENI
6-Contributor
(To:Remy25)
No comparison between them.
it's like one is RAIL and another one is CAR. still, both are used for travel only.
but, still so much difference. I hope you understand.
Remy25
(To:GAINSREENI)
Ok, I understand.
Thanks for your information.
Florent
(To:Remy25)
Same question here: Windchill-ERP integration  where I proposed the ESB (unlike to point-to-point link or "bridge"): the 4CAD LINK 2.0
Florent ROUSSEL
www.4cad.ca
Remy25
(To:Florent)
Thanks Florent,
I will check.
