Error / Notice
wt.wrmf.delivery.WTDeliveryException: wt.wrmf.transport.WTTransportException: java.net.ConnectException: Connection timed out: connect
Nested exception is: java.net.ConnectException: Connection timed out: connect
Nested exception is: wt.wrmf.transport.WTTransportException: java.net.ConnectException: Connection timed out: connect
Nested exception is: wt.wrmf.delivery.WTDeliveryException: wt.wrmf.transport.WTTransportException: java.net.ConnectException: Connection timed out: connect
Any ideas?
I am trying to setup two replication servers and am down to mounting and cannot. Software on servers is installed, CCSUpdate has been run. All codes match. Windchill is running.
You can try checking your firewall ports
was the blasted firewall....
