Hi Guys,
Can we bulk print or bulk PDF get in locally? Is it possible in Windchill?
Regards
AJ
Yes, this can be done from the clipboard and batch print PDFs via Creo View. Copy items (which puts them in the clipboard), there you should see options to batch print.
Hello @Amirtharaj_K,
It looks like you have a response from our community champion. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
