Bulk deletion of attributes in windchill
SS_10574885
hi team,
There is a scenario I need to delete 75 attributes in windchil
This is tedious and can we have a bulk deletion loader or how can it be done through build deployment?
@HelesicPetr  can u guide on this or route to guide?
HelesicPetr
(To:SS_10574885)
Hello @SS_10574885
You can use load from file method.
Here is an article describing how to load attributes to the system.
CS30168 - How to export and import soft types and attributes using 'LoadFromFile' in Windchill
If you import one attribute, and system contains additional attributes then the method generate XML file in a Windchill/temp folder for deletion the additional attributes.
You can use the load from file method to load the generated xml to delete the attributes.
PetrH
Hi @HelesicPetr
Approach you have suggested only delete the attribute created in type  Is it possible to delete the attribute created in Manage Reusable Attribute via LoadFromFile  ?
HelesicPetr
(To:MS_9630520)
Hi @MS_9630520
No, the load from file is not designed for delete objects generally.
I do not se any reason for deleting global attributes.
btw, you can write own utility to do so.
PetrH
Hello @SS_10574885,
It looks like you have a response from our community champion. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
